sporty gearing
  • brucecul
    brucecul
    has anyone out there changed the gearing on a 07 sporty to make it better on the highway ?.
    Is your bike a 883 or 1200 ?
  • brucecul
    brucecul
    You can fit a 1200 Front Pulley on and you will pick up more top end
  • brucecul
    brucecul
    do you know how many teeth the 1200 front pulley would be ?.
    hi, the 1200 pulley is 29t   2 teeth up on 883  27t , olso fits same rear belt , cheers
    sorry , i stuffed-up  on  pre 04  883 is 27t & 1200 is 29t , on 04 later 883 is 28t & 1200 is 30t  i think the belts are 1 tooth differ 136t/137t  ,  cheers i will know more next week as i am doing  a 04  & a 07  883  to 30t pulley set-up  cheers
    hi, just done a 06 model sporty 883 front pulley was a 28t brought original 30t off a 1200 sporty, $110 easy swap, rear belt adjustment on the rear axle in the swing-arm went from from just before the rear of the centre of adjustment to the 1/4 front middle of the adjustment range still using the stock 883 rear belt .
    the harley bar & sheild on the belt is pepermint green on 1200 & on the 883 its orange colour . it could be 1 tooth differ as differ colour bar & shield for differant belts on stock bikes , cheers
  • Big Arnie
    Big Arnie
    Did you have any trouble undoing the  1 3/4 inch nut on the shaft? I know it is reverse thread but I had to abourt as even with breaker bar could not loosen it. What tools did you use to undo yours, cheers.
    hi, i use a small air rattle gun only to un doing the left hand thread , it has loctite on it so it is on hard  because they can come loose because the pulley is so heavy , cheers
  • Big Arnie
    Big Arnie
    Thanks daddyracer will give it a try. I suppose the rattling effect is what does it. I even fabricated a locking device so the sprocket wouldn't move. Veeery tight indeed! (just how we like em LOL)
    hi,i adjust the back wheel tension up a bit  untill it's just -on firm (no slack ) & hold the back brake on at the same time as you undo it  if it's too tight,    put it into top gear also with the back brake on ,     cheers
  • Big Arnie
    Big Arnie
    Thanks again.
