Online: John.R
Tacho
  • billie
    billie
    Hi guys
    Have a ferret around the forum with no luck
    Q is it straight forward to fit a tacho on a2007 softtail and if so where do I get a tacho from & how are they fitted up??
    thanks
  • Rowdy
    Rowdy
    How are you billie,if your bike is injected you should be able to buy a genuine tacho speedo combination that will simply replace your old unit,thats what Ive got for my 09 dyna. If you want to fit an aftermarket tacho you will have to run a tacho signal wire from your ecu ,I run a shift light aswell and had to run a new wire from pin 3 in my ecu as I needed a tacho signal wire to run it ,dont know if softtails run the same wiring but imagine they would .
  • billie
    billie
    Thanks mate I will starg getting some prices for the unit
  • OSP1340
    OSP1340
    I mounted a tach on my Dyna and did the same a Rowdy.
    But my tach mounts to the stem nut.
    Follow this link to the one from Alloy Art. I ended up getting mine from Vtwin as they were a little cheaper but can't find the link for it.
    http://www.alloyart.com/products/sm.html
