TTS Mastertune Update August : what's new ?
  • streetdjack
    streetdjack
    Hi there
    Found a new update for the TTS HD Software today ... Can someone of the TTS crew explain a little more about it ?
  • Steve Cole
    Steve Cole
    It's all on the upgrade service as of now. So anyone with our software can download the upgrades. There are all the files for all models but we are still working on more for the Touring models. As we complete them they will be added but so far you have 5 base files to start with, 96 cu. in., 103 cu.in. and 110 cu. in. It will take a few weeks to finish the balance but there will be about 15 base files for the Touring models when finished. The update does make a few changes to allow for running with Lambda but nothing major changed. It all still works the same basic way. We added a few calculators so those that are not familiar with Lambda can convert between Lambda and AFR on the main form and under the "Tools" directory.
  • streetdjack
    streetdjack
    Thank you for the answers, guys
    Hi Oz, everthing's fine, thank you ... the bike is "on the bench" for the 24 000KM service and I'll add an oil cooler as well ...
    Next, I'll begin the tune with my new Supertrapp SuperMeg exhaust and I'll do the dyno as soon as possible ...
    I also have soon a 2009 StreetGlide to tune, could I use those new maps with lambda or should I stay with AFR ?
    Have a nice day !
  • Steve Cole
    Steve Cole
    Well just to screw with you all some more there are a few new updates for you. One to fix my fat finger problems so you will get a new version of Mastertune v136 now. Most of you will not notice any changes with it. The other update is for more base calibrations for the 2010 DBW Touring models, this bring it up to 13 base calibrations for the 2010 Tourings. I've got a few more to finish up and expect to have them finished and released by the end of next week.
    Happy tuning.
  • Rooster
    Rooster
    Is there a maximum character limit in "Tuning File Comments" table.
    I seem to have written all that can fit here!
    Increasing character limit would be good in an future update.
