Online: GGUser731
Harley Performance
  • R & R Cycles
    R & R Cycles
    Hi Guys,
    Welcome to all new members, its good to have you all on board!!
    We have had some members asking us a few questions lately about Performance Modifications, mainly about adding some big bore barrels and Kits that we supply etc.
    Guys, Remembering what it is that we do here at R & R Cycles, and that is adapting your Harley Engine to perform well across the Rev Range, which requires a balance of components that are required to be fitted, and tuned and in most cases modified(Remachined)by us, to suit R & R Cycles standard.
    I understand that a few of you just want to add the big stuff, however this will actually put your engine way out of tune balance, through the many hours we have spent at the Dyno we have found that with certain parts that are added to your Engine with the expectation of improved performance, you are actually reducing the the performance and most importantly the efficiency of how your Harley Engine will run.
    Please Log in and read our Dyno and Tech Pages  http://www.randrcycles.com.au/
    If you have any further questions please dont hesitate to drop us a line, and we will do our best to ensure you have a satisfactory answer that will help you to understand what your Harley Engine will require for Optimum and Efficient Performance.
    Regards
    Rick
    R & R Cycles
