Online: Retroman, John.R, Hilly
FRONT FORK RELECTORS
  • elmodog
    elmodog
    Gday all How do you SAFELY remove the relectors from the front forks, ive heard a plastic putty knife is the go, but what about the coating on the forks, and will eucalytus oil work for removing the residue
  • twincam88b
    twincam88b
    Ask Bano, he's the expert on reflectore.
  • kingchops
    kingchops
    Just use an old rag to save your fingers and slowly prise them off by lifting one side with your fingers. I messed around when I did it to my old bike but I just ripped off them the Bob and it worked fine. Clean up any residue tape with RP7.
  • kingchops
    kingchops
    Oh and send them to Bano once you're done.
  • matt08
    matt08
    the front ones come off easy just grab the reflector and twist them off
  • Tbolt
    Tbolt
    burn the fuckers...........
    who needs reflectors anyway..........
    TB
  • Bender
    Bender
    I used pliers and that worked well and hair dryer will heat the glue and they basicly fall off.
  • Peter
    Peter
    You know I've given this a lot of thought and, I think the easiest way to remove them is to beat the fuckin shit out of them with a hammer then pick off all the little pieces and set fire to them at night, then throw the burning embers at the cat who will run away on fire which will make you laugh and you will not have to feed the pussy for a couple of days because it won't trust you anymore. Then send the cat and the embers to Bano. The End.
