Online: John.R, Hilly
Smoked Taillight
  • Peter
    Peter
    Does anyone know where I can buy a NON LED smoked taillight for an 09 softy ?? The only one I have found so far is a Kuryakyn brand for about $60 but it has the clear window for the number plate light on top instead of the bottom.
  • Peter
    Peter
    Dunno ? never tried it, but it is a lay down taillight so probably not.
  • Peter
    Peter
    Yeah this one is saying it will fit 04 to 09 softails, but then makes mention that the clear window is on top so I dunno what to make of it. I don't wanna buy it then have to send it back. There must be something else out there ??
  • Peter
    Peter
    Too expensive for me Dave.
  • Peter
    Peter
    I emailed em and they said that they do have one that faces down, and that was all they said. Beats the shit outa me.
  • Peter
    Peter
    Just looking for a standard but smoked taillight Jill, but I will have a look anyway. Yes I have been to his house and some of his gear is very good. Hope you are enjoying your new bike.
  • Peter
    Peter
    Ah my mistake, I thought you picked it up this weekend, must be loosing it because I already told you I was going south the same weekend.
  • Peter
    Peter
    Thanks Scotty, so if it has no clear window how do you see the number plate at night ?? Or am I missing something ??
  • Peter
    Peter
    I suppose what I should have asked is - does everyone just use the NO CLEAR WINDOW taillight on the softail standards or customs ?? And do the cops worry about it if ya do ??
