Online: Retroman, John.R, Hilly
Bike Stand
  • 91FXR
    91FXR
    Bought this bike stand today from Repco for $150. Seems quite sturdy and is easy to use.
    I thought it was a good price so I am letting you all know. It is on special at that price till the 6th of september.
  • Daggs
    Daggs
    good on ya ! cheers
  • Ozbiker69
    Ozbiker69
    That looks very sturdy and should do the job for me with my old Softail Custom. will check out Repco here in the morning and see what they have.
  • Peter
    Peter
    Make sure the distance between the lift arms is wide enough to sit either side of the softail shockies.
  • Nibbla
    Nibbla
    Hi FXR, The jack & bike look good but Im interested in the forward controls, I have a mate looking for some, can you tell me the brand, price & where you got them?
    It's hard to find controls for the FXR's.
  • roadie
    roadie
    I presume it uses a hydraulic pump? Certainly great for working on the wheels but I guess not oil changing. Good price.
  • twincam88b
    twincam88b
    This subject has been covered back in the dark ages, but hey that looks like a pretty good deal, and it looks quality. It's the first one I have seen used with straps, I rekon mine has the loops for the strap hooks, I must check. I haven't bothered, but then again I don't wheel it around. Just lift the bike to wash it and put it back down when finished. Great for cleaning the wheels, especially spoke ones.
  • AJ56
    AJ56
    I have one of them. They not to bad. Good for cleaning the wheels . I have used it for servicing although it is a bit of a hassle when doing the Gear box.
  • poverty rider
    poverty rider
    I bought one of those lifts from Repco a few months ago for a lot more than $150 so you've got a bargain. Good for cleaning your wheels.
    Also, you can hold your bike level by raising one side arm under the front of the frame. It's steady enough to do gearbox and primary oils.
  • aussiesport
    aussiesport
    bud check all the bolt holes and the points where anything is welded regular like ....personaly i made my own mega heavy duty i can jack up a mack truck ;)
  • Tengy
    Tengy
    Good info
    Bought one and so far I have spent time welding the lock release guides back on. Other than that it seems to be worth the coin. I have to take everything off the back end to change the tyre so will come in handy.
  • Soapbox2627
    Soapbox2627
    I got one last year, same price, finally set it up and the jack was empty, put some oil in, still don't go up, I think the release button is stuck, a bit of work for me to do
  • 09 SOFTY
    09 SOFTY
    Yep got one from the kids for this fathers day..and the seat on castors to match...........( even had to set it up myself and hide it in the shed so the kids can surprise me  ,but seems to work ok ...................so ive heard ..
  • Soapbox2627
    Soapbox2627
    there you go, I knew it, Giraffe exhaust are available
  • Buelligan
    Buelligan
    ALL SHOW!!!   NO GO!!!   ------    You think that trucks great, love to see the one that transports it around between shows, cos don,t think it gets more than start up every now and again to give the owner "Wood"
                 One thing in its favour, thats a shit hot paint job, just missing the lettering "K"  "T"  "M"   on it anywhere
  • aussiesport
    aussiesport
    whats with the giraffe dude ?!
  • aussiesport
    aussiesport
    there ok for small things like dumpin oil etc but not real good for doing wheel work etc ..there are heaps of diffrent lifts out there just price varies ...
