Online: DIVOT
Would love your tips on a go fast package that won't break the bank or the ride-ability
  • SuperGlide
    SuperGlide
    Big question here I know, but you blokes are always so helpful I thought I'd throw this one at you...
    Let me know what you think is best to get more power from my bike, and we're talking a solid good new whack of power. I'm not to good doing this stuff myself so I wanna end up with the right set of goodies working in combination and then I will source them and find someone good to put it all together.
    As for details, I'm not going to pretend to know more than I do, so however I let ya' know what I do / or want
    and then you educate me as to best combo / bang for you buck...
    THANKS HEAPS... bike is still under warranty etc but I'd like to get your suggestion into action in next 6 months.
    I like to;
    - Have good useable touring power (& some fuel economy) as I often do +400klm rides and I also like to take the missus away for weekender's etc.
    - In saying that I don't mind if the bike is a bit lumpy, bit of a handful etc, in fact I like that and have had many Hi-po cars / drag cars etc.
    - I like to hit the drag strip at WSID and would like to improve my times there but don't want any overheating probs tho for summer/city etc.
    - Budget wise I guess I'd go up to a maximimum of $6k total incl labour etc.
  • SuperGlide
    SuperGlide
    Thanks.
    Sounds good, yeah I can freight stuff from US cheaply too. I have bought quite a few bits from Zanotti's already.
    110 hp? what's a Dyna run stock 80 hp?
    No tuner, I have standard Puter' in there just slip on exhaust is only thing at moment.
    With this package and 10.5 compression etc would i need thermo fan or oil cooler or anything else to run cool etc.?
    So to keep engine more stock and go for SuperCharger is not the way to go then?
    How do the 2008 HD gearboxes/clutches go with the above kind of power increases?
  • SuperGlide
    SuperGlide
    And he's saying this upgrade will result 110hp?
  • Bobtail
    Bobtail
    I would think with those sort of figures Oz, that a clutch and crank upgrade would be on the cards as well......
    For me a moderate 103 with Andrews 54H and heavier clutch spring will do...hope to get 90 to 95HP (maybe 100hp if heads are ported and a 2:1 exhaust etc) and 100-110 TQ....The cost of all this will be under two grand, instal by me and friends......
    There is nothing more satisfying than to have a bike that is responsive and has gobs of torque........When me bike came of the shop floor in standard trim I was somewhat disappointed, 68 HP pushing near 400kg all up was not too thrilling.....to now the upgrades have transformed the bike, getting just over 80HP with A/C, SE 204, TTs and Pipes......
    Bt
    Oz i don't like the SE race clutch. know a few that have used them.
    with clutchs, you just wait till they slip, a sliping clutch don't hurt that much, in fact can help performance, a clutch that has no slip can break gear box's.
    the VPC is a good idea, allows light pull and puts pressure on the clutch plates when you need it, i don't use one but, know a few that do and they ride and race, just need someone that knows to put them in for you or could have problems.
    i have the S&S Clutch best i've had yet, i had a bandit mach super clutch on a shovel, but like you say the stock clutchs are good to a point.
    also you put more HP & TQ and you get more pressure on the gears and makes it hard to shift fast.
  • BACAMICK
    BACAMICK
    I Love My VPC
    gota admit when i had it in my evo train it was a bitch to change gears on full racing , now i have it in my 07 dyna i never use the clutch to change wen racing, not sure why it changes so easy , could be the new trany desingh or the mobil1 i run in all holes, mobil 1 since day 1 so i dont no any diff
  • SuperGlide
    SuperGlide
    Bloody top stuff all, THANKS. I've been reading all this with interest.
    Sounds like Ozroders Tman packaage is a good thing. Would be good to get out to 107 though for that kind of money.
    I have a good mate that's introducing me to a mechanic bloke that does alot of porting for the MX teams and bikes in general, he's a big harley nut too though apparantly. Also have a good referall from KrashK re a bloke to bolt it all up and machining etc.
    Wack on the Bassani Pro street pipes for sure, and clutch I think leave stock and see if the slipping becomes too much over time.
    ALOT of people seem to talk about those Andrew's Cams.
    TTS sounds like a goer, to change to closed loop for normal riding etc is that just a plug and play thing that you do at the track?
    Do forward controls have an impact on the shift over midmounts do they??
  • KAOS
    KAOS
    this is interesting. Am just about to release the purse strings on my build and then this 106 S & S kit rears its head.
    Scotty can you tell me if the S & S pistons are forged or cast ?. Is there an option ?.
    Also, can you tell me if S & S heads out of the box are any match against a set of stage 3 heads from the states. Cant work out the S & S website to even find their heads and prices.
    Superglide - can you give me details of Mom & Pops ?? Sorry I just havnt heard of them before.
    Thanks Guys.
  • SuperGlide
    SuperGlide
    Sorry dunno why I keep calling it Mom & Pops, it's M&M, bit tricky working it out but you can download cataolgues or just search by part number.
    http://www.mandmcycles.com/
    I usually go there first for a sticky beak
    but have so far bought almost all stuff from http://www.zanottimotor.com/
