Online: John.R
Sportster 883 Question
  • Smoky
    Smoky
    Hi , I have a 2009 XL883 sporty. I was wondering if any body has heard of a way to change the gearing on the final drive so that she isn't screaming her head of at 110kph. May be making the front cog bigger or the rear one smaller. I asked the local Harley dealer and he said NO. But I thought there may be some after market way.
    Thanks Smoky.
  • kingchops
    kingchops
    The 883 is geared for better low end performance, so it does rev high at high speed. A common practice when people do a 1200 upgrade is to change over the engine side sprocket to a larger one, the 883 has a 28 tooth and the 1200 has a 29 tooth from memory.   But no reason you can't change your 883 to a 29 tooth if that's what you want.
  • DynaRider
    DynaRider
    It used to be a 27 T for 883, to allow for better acceleration
    and a 29T for 1200
    we used to change them out when a 1200 conversion was done
    I do not recall having to change the belt
    Supermax products have some options
  • BACAMICK
    BACAMICK
    i often sit on 150k on the missus sporty  , NOT ON THE RD  and the 07 883 seems to love it
  • Smoky
    Smoky
    thanks for all the info, it has given me alot to go with. Hey jilli96 my sporty is the same colour , it sure looks good.
