Online: John.R
running like sh**t
  • kiwi
    kiwi
    Had my 204 cams installed and bikes running hot and idle up and down as well should i have had it remapped straight away.Thanx kiwi
  • kiwi
    kiwi
    Its a 2007 dyna superglide , high flow air filter ,vance and hines shortshots,s,e,p,s,t, i got a quote for a $1000 for the cam install and a dynotune, i asked the bloke if its going to need a map and he recond that it should of been ok which it turned out it wasnt and he reccommended it be remapped as it turns out that was an extra $300 which i didnt have on me so took the bike back home 2 and a half hours away feeling a bit pissed off
  • kiwi
    kiwi
    $1000 for the install of the cams and labour yea was a bit pissed off with the lack of interest they showed(disappointed).
  • BACAMICK
    BACAMICK
    would make more sence to put the $300 towards a T/MAX and never need a dyno again ,
    that sucks mate , need to put them in the SHAME file so ppl no they dont give a F@#K
  • DynaRider
    DynaRider
    or $300 towards a tts and never need a dyno again
  • andij
    andij
    a pro dyno tune usually takes 3 hours off and on unless you change engine variables it will stay ot optimumn .
  • DynaRider
    DynaRider
    one thing we know for sure about aero start
    it does not cause engines to stumble or stall
  • shifta
    shifta
    bet you it dose
