Online: John.R
Oil Filter 1340
  • wildchild
    wildchild
    I found this on another forum and it alarmed me about filter selection.
    Basically the EVO oil filter is 30 microns in filter media and the Twin cam is now 5 micron. The oil jets that cool the bottom of the pistons in a twin cam engine need the 5 micron rating otherwise they will not be able to function once they get clogged and the pistons will heat up more than they should.
    I have an EVO and Twin Cam, just did a service on both and used the Twin Cam filter on EVO and TC.
    Should have used a 30micron filter on the EVO, only did about 60klms since oil change...what damage if any would be done running the 5micron over the 30micron filter?
  • Deadly
    Deadly
    No real idea but maybe it could hold back pump pressure = bad (wind the idle back up to where it's meant to be)
    or filter crap out of the oil = good
