Just 103 BB
  • Fr3d
    Fr3d
    I have a mate with a 07 dyna who is looking at boring his barrels to 103. No new cams, no head work just SE slipons and SE a/c.
    We were both wondering what to expect, wether the stock cams will work better or do we need to put other cams in?
    Thanks in advance
  • Fr3d
    Fr3d
    I agree the cams/thinner head gasket should go in but he just cant spring for them at the moment.  The BB is the just cashing in on some warranty work and just wanted to make sure it was not going to be a backward step given everything else is basically stock.
    Thanks for the comments
  • BACAMICK
    BACAMICK
    at least do the gaskets , cams can come latter
  • BACAMICK
    BACAMICK
    probly , i dont no , wat would be his worst serario ?
  • DynaRider
    DynaRider
    BEST case scenario may well be less power output due to tuning compensations made
  • andij
    andij
    if ya not gonna change the cams ya wastin the 103 kit .
  • DynaRider
    DynaRider
    if the bike came factory with 103 capacity option for free, who would not grab it?
  • PigironBob
    PigironBob
    Surely a 103 would come with a set of cams?  Maybe get the part # and check to see if it's a kit or what ever.
  • Fr3d
    Fr3d
    PB, just to clarify - the bike is burning oil due to leaking valve guide seals and warranty will replace seals and hone barrels. He wants to pay the extra while the top end is broken down and BB to 103. Still will have stock cams with new flat tops. We are wondering how the bike will run with the stock cams and whether they will be ok for a while or does he need to put in new cams.
    Thanks
  • PigironBob
    PigironBob
    Ok, it will probably run like shit and be under powered, be better if he gets some cams in it.
  • DynaRider
    DynaRider
    it will not run like crap
    and it will not have less power
    it will just not reach it's full potential, but it wll still be a plus
    just not as incredible a plus as having a few other extras with it
    but if harley made all their new bikes with that exact combination, you would not see anyone trying to reduce the capacity to 96, in the belief that they would gain power
