Online: Kato
Seats
  • Marty
    Marty
    Do the night trains share the same frame as a fatboy ?, the reason I ask is i'm looking at a second hand seat from a night train and want to use it for my fatboy
    Thanks in advance, Marty
  • BlackDragon
    BlackDragon
    Hey Marty
    All softails are basically the same for certain years.
    Depending what year ya bike is the Badlander seat should fit.
    Go to the HD.com website and check out the accessories section. Will tell U which seat will fit for your year.
    06 softails with the 200 tire probally wont fit a 2005 earlier soft. and 1999 won't fit a 2000 up.
    There not that expensive either but once Ya know which one yer after will make life easier.
    Regards Greg
    i237.photobucket.com/albums/ff263/iam_BlackDragon/1.jpg
