Online: John.R
Fork Tubes
  • Pom58
    Pom58
    Anyone know the inner diameter of a fork tube used on a 97' dyna super? is it 41mm.? I'm thinking of putting Ricor Intiminators on to fix up a sloopy front end. Cheers Pom
  • DynaRider
    DynaRider
    they are only 39 on the outside, so no is the answer
    35 ish you would imagine, given 1 or 2 mm wall thickness
    I used to used gold valves in those days, and they were model designated, so never measured the inside
    pd valves are also sized, but their biggest is the one for 49 mm forks,so again, I did not take particular note of the actual size measured
