Online: John.R
All Bore 107 Kit
  • hellboundpig
    hellboundpig
    Gday steve i went with 103 kit sreaming eagle 211 cams 0.30 gasket usual pipes air cleaner and thundermax on 07 softail standard
    goes hard only problem i have is hot starts could be the amount of fuel fill from my thundermax tuner i am sure some one will correct me if iam wrong
    i wouldnt go to big on the cubes with out doing crank modifacations and bearings my camshaft bearings fell apart when they were removed cheap crap gearing replaced
    them with torringtons for piece of mind good luck wit your choices.
  • DynaRider
    DynaRider
    to use the 204's with the 107 kit would give very high cranking pressure (over 205 psi)
    the fuel you buy at the local servo, including the 98 octane, is unlikely to be adequate
    an ecm tuner is to enable you to correctly tune a good engine combination
    it is not some magic unit intended to turn poorly blended parts into awesome power makers
    seeing as you intend to keep your heads stock, which barely flow enough for a 96, you should think
    about your intended capacity and compression ratio/cam combo carefully
    parts that complement each other well, work better than having "one big spec" in the mix
  • andij
    andij
    sounds good advice from the boys 204s are bolt in for stock motor theyd be stock cams except for epa regulations .personally id go pc and get a good dyno less muckin around then other ignition changes
  • aussiesport
    aussiesport
    buy a ducati bud ;)
  • aussiesport
    aussiesport
    hehehehehehheheh dang them there ducks are quick :)
  • SuperGlide
    SuperGlide
    Good info boys. Dunno if you'd like to contribute to this....
    http://hdforums.com.au/Default.aspx?tabid=71&forumid=24&postid=152345&view=topic
