Online: John.R
Forward Controls
  • Cuzzybro
    Cuzzybro
    I ride a 2006 CVO Fatboy - FLSTFSE2. Trying to find Billet Forward Controls that will fit without having to drill or modify the frame. Has anyone got part no's or photo's. Going to Brisbane/ Gold Coast next week. Are there any good shops I can go and look at that may stock them? Thanks in advance. Would also like to take my seat over to get a bit more padding into it. So would appreciate a name of a good shop.
  • Cuzzybro
    Cuzzybro
    RT,
    Plan is to buy overseas but need part no's. Did you have to do any mods to your bike or buy an adaptor plate to fit it? I am 1.83 m. Can you advise how you measure for the right fit?
  • Cuzzybro
    Cuzzybro
    RT,
    Thanks for the info. Much appreciated. 3 " extension sounds like the go. Cheers.
  • GREG
    GREG
    I'm 186cm tall and have the 3" extension kit from Ness. Does the job perfectly, heaps of room.
