Online: skirtster
What's a Pet cock?
  • poverty rider
    poverty rider
    Try this website http://en.wikipedia.org/wiki/Petcock for your answer.
  • Peter
    Peter
    If you owned a petcock would it cum when it was called ??
  • Soapbox2627
    Soapbox2627
    Didn't a "sensative" young lady take her employer to court because he let another woman have her "pet cock" (soft toy penis) in a little bird cage stay on her desk.
  • kiteman
    kiteman
    Would there be some advantage to fitting one?
  • Peter
    Peter
    If you didn't have a way for the fuel to get to the carby there would.
  • Peter
    Peter
    Thats even funnier LMAO
  • Magilla
    Magilla
    errr........... hello cocky ........arkkkk
  • Bobtail
    Bobtail
    Gawd, FFS.....every-one knows that it's a cock ya put petrol in
    Bt
  • Chips
    Chips
    All jokes aside Jilli ... it's a fuel tap on a normal carb bike. If you're still buyin' the softail, it will not come with one and you don't need it. The fuel injection system will have a quick release fitting in place of the tap so you can disconnect it without the fuel draining from the tank. When it's connected the fuel is always on.
    On a "lessons learnt" side always remember to disconnect the fuel line if you're ever going to move the tank. The other end of the line at the throttle body, has a pissy plastic fitting which WILL snap if too much lateral force is applied....
  • Tapey
    Tapey
    I had the plain old Petcock, and then i bought a chrome skull to go on it..., now i spit on my Petcock and polish it.
  • Firey
    Firey
    Tapey thats a beauty!!
    I think all the ladies should have a spare Petcock because some work better than others, they can keep them in the cupboard and only grab it if needed, they come in 2 different colours, never winge when used , and they work the best when you turn them on
