Online: B0nes, Hilly
Harley secuity
  • ozzybob2
    ozzybob2
    Hi , I need some info regarding my 2006 deuce . i bought a wrecked harley from the USA with no fobs . fitted everything into another frame , the security is armed (lights flashing ), i want to introduce new fobs but it is armed and wont let me disarm it to start the process to give it two new fobs ,im guessing i will have to buy a new tsm , unless some one can help me some how ...i appreciate any info .cheers
  • ozzybob2
    ozzybob2
    Thanks Bano , I was sort of hopeing there might have been a limp mode like holdens perhaps , leave the key on for 30 mins start car , get home or to a dealer and if you turn it off ,wait another 30 mins etc , but it looks more like i will need to get a new tsm to me , ive been to a harley dealer and they cant get a fob to it unless it is unarmed.many thanks anyway , hope you get drunk and laid on the weekend ...get drunk first and youll be a better lover, ask any drunk . cheers
    I'd ring another dealer and see if they say the same.
  • black29d
    black29d
    There is a Limp mode as you put it
    but guess what....You need the fob to activate it
    the bottom line is that you need to have the fob, or the bar code in the manual when the bike is supplied new from the dealer,  to bypass the system to get the limp mode
    if you don't have either, you are going to have to go to a dealer
