Online: John.R
gear shift link
  • LASSE
    LASSE
    How to remove on a 2008 softail?
  • Lastrain
    Lastrain
    .... WTF ????
    Am I missing something here? or have have you not even had a look at your bike?
    not rocket science at all, 2x 1/2 inch spanners, losen lock nuts and undo, less than 2 minutes ?????
    Remember lefty loosey, righty tighty
  • odinsvolk
    odinsvolk
    If you change gear fast enough it will break  off like mine
  • odinsvolk
    odinsvolk
  • LASSE
    LASSE
    I just took it of and Iused a 11mm and 1/2 inch. each end have a bolt with a ball in one end and swivel in the rod end and seems to be impossible to take off. Just waiting for a flame rod from Harley. I hope there is parts to fit the new rod.
  • LASSE
    LASSE
    Yes lastrain, you missed something. Have you looked at your bike? what you suggest is for adjust the length of the rod.
