Online: B1ack, John.R
new member, Gosford, need help.
  • russell327
    russell327
    hi guys, I have a shovel. and yes I know that this bike allways gives troubles, its ok . I am a mechanic.  my problem is I am about to pull the motor down, and was wanting a phone number, or address for me to buy a ring compressor for a harley. thanks guys and girls.
  • homerd
    homerd
    Howdy Russell, welcome to the forum, sorry can't help ya with what your chasing, no doubt someone will be able to, all the best.
  • Hoodaman
    Hoodaman
    welcome to the joint mate....good luck with the shovel but im sure u will find the help u need on this forum.........
  • Etch
    Etch
    Welcome Russell hope you enjoy the forums and stay safe out there.
  • FXD09
    FXD09
  • JD
    JD
    welcome
  • BAKES
    BAKES
    G'day Russell
  • robert65
    robert65
    gday russ welcome to the forum.
  • The Don
    The Don
    G'day Russ,
    Welcome, especially as you've got a Shovel!
    Regards,
    the Don
  • DaveP
    DaveP
    Hi Mate, welcome.
    Just take your piston to Repco and ask them for a stainless steel clamp with the same diameter. Last time I bought one in Gosford it was under 10 dollars, only needs to be long enough to cover the rings. I still have it and used on many a shovel over the years.
    They used to have a good one with a 7/16 nut on the end. Also seen them in truck shops for exhaust clamping end caps, bling etc.
    Cheers,
    Dave.
  • toxic
    toxic
    G'day Russ & welcome m8,  have ya tried BUB's up the hill @ Kariong ?? he should be able to help ya out.
  • twincam88b
    twincam88b
    Welcome to the forum Russ, enjoy the ride.
  • wideglide96
    wideglide96
    g`day rassel welcome to the forum ....hope to see some pics of the shovel soon
