Online: Retroman, John.R, Hilly, Rextheute2022
Mustang seats
  • periphot
    periphot
    Hey guys, anyone have anything to do with mustang seats.  Looking for a good pillion seat for the Nightster.  Don't know whether to spend the extra moneyn on importing a mustang one-piece touring seat or the HD Sundowner.  Any views approciated
    I purchased the Mustang Solo and it is a huge improvement over the stock seat. Recently purchased the pillion seat for the solo, but has never been used as bike is in Brissie and I'm O/S.... looks similar to stock pillion for the Street Bob... Not much you can do with pillion seats so the air ride cushion might also be the go
    Purchased my seats from Zanotti's... from memory had to convert the Mustang P/N to Drag Specialties to buy through Zanotti's.. price was below Mustang's list.
  • 1elcys
    1elcys
    Get the Mustang
    I had the Mustang vintage seat on my sporty and put 40,000k's on it in 12 months, damn! wish I still had that sporty.
  • Rooster
    Rooster
    I am looking for a better seat for my sporty. Had a look at the Mustang range and they look good. Think I will get one.
    Which size did you fellas have the 12.5" or the 14.5".
    I am assuming they are good for longer rides. The stock seat is only good for about 150 km.
    Cheers ..... Rooster
  • Bear
    Bear
    I have a two up mustang seat on the King, have found it really comfortable on the long haul. When you're doing 1000+km days you really get to know every stitch or lump of foam, and I've never had an issue with it. Has served me well.
    My pillion assures me it's a big step up from the stock seat as well.
  • banjo48
    banjo48
    I put a Mustang on my Softail about 18 months ago, as my other half refused to ride on the standard pillion one! I also suffer with back problems.
    Got mine from Cruiser customising in California, took 6 days to arrive to Perth WA.
    Its just so comfortable and even with $70AUD freight was still $200 cheaper than anything similar here.
