Online: Carizo, tussuck
Clutch cable oil leak
  • gonzo
    gonzo
    Hi All.
    My gearbox is leaking oil from where the clutch cable enters. It's not much, but it's getting the bike grubby. I've had a look at the manual, and it says there's an o-ring, which I assume is responsible for sealing the oil. Before I pull the cover off, is the o-ring part of the cable assembly, or a separate part?
    Thanks,
    Gonzo
  • gonzo
    gonzo
    Hmmm.
    I've got the o-ring now.
    It seems that I've got to
    a) drain the tranny oil
    b) remove the exhausts
    to replace the o-ring.
    What a pain in the arse!
    Gonzo
  • gonzo
    gonzo
    THAT'S what I wanted to hear!. Thanks Scotty.
    I guess the new design (09) rear cylinder header would avoid the problem of the clutch cover...
    Anyway, I won't get a chance to try it until the weekend.
    Gonzo.
