Online: Carizo, tussuck
Front Lowering Kit
  • NYTRN
    NYTRN
    Ordered a set of Shotgun Shocks to be installed on my 09 Night Train in the near future and have been looking around for a front suspension kit to match.
    After a bit of reading looks like the Race Tech front suspension kit with springs and gold valve emulators seem to be the go.
    Just wondering if anyone knows where i can find parts number, or info on this kit for an 09 Softail. Also i noticed that you may have to match the kit with your body weight. So what would i need to suit 220lbs.  Which i think pans out to be 1kg/mm.
    Done a fair bit of searching just can't pin point the exact kit needed.
    Cheers.
    NT
  • NYTRN
    NYTRN
    might just try and ring through to race tech in the states late monday night. See how i go
