Online: Soapbox2627, Businessfare, Rextheute2022
exhaust system
  • bez
    bez
    Finally got my lepera seat re styled so i can sit on it for more than 50kms.:)
    Still looking at getting vance & hines straight shots for 94 sportster.
    My question is, with the vance and hines you dont have a balance tube, does this cause any problems as in backfiring or popping ?
    Bez
    No you dont need a Balance Pipe, and If the Bike is jetted right it will not Pop or Back Fire
  • bez
    bez
    Well i guess thats answers that. thanky <img src=" align="absMiddle" src="/DesktopModules/NTForums/themes/_default/emoticons/smile.gif" />
  • bez
    bez
    thnx :)
  • DynaRider
    DynaRider
    the balance pipe is mostly effective in mid range, whereas the popping is a low speed circuit mixture issue (not meaning you are necessarily travelling at low speed)
