Cobra Pipes fitted, great
  • keego33
    keego33
    Finally got my Cobra Speedster Pipes fitted, they work real well and sound great. Yet to fit up the Cobra FI2000 to the wiring injectors and
    O2 sensors.
  • BACAMICK
    BACAMICK
     nice
  • DynaRider
    DynaRider
    they look good on there
    did they fit accurately?
    or was it a massage job
  • keego33
    keego33
    Every part fitted as per the fitting instructions, I followed the fitting instructions exactly. It took me a few hours, pulled the stock system off one night and fitted the Cobra system the next night. No doubt a bike shop would do the job much quicker.
    After the first ride I had to retighten all the bolts and clamps again, lucky I did because some had come quite lose.
    Went on a 300km ride today, a big improvement, still not to sure about the loudness, might try the quiter baffles.
    Next step is to fit the FI2000.
  • keego33
    keego33
    I am sure they are, considering trying the optional baffles to make riding a little more plesent. The exhaust note certainly attracts some attention.
    The syetem also changed the motor, I am told the fI2000 really does smooths the motor out.
  • keego33
    keego33
    I installed the optional baffles to the pipes tonight, I am much happier with the exhaust note now, not as sharp or as loud but far from quite. Much easier on the ears when cruisen at 100/110kph.
