Online: clackavosticus
oil pump upgrade
  • CHARLIE
    CHARLIE
    Am going to fit a set of 203 cams and was wondering if anyone knows the part number for the upgrade model oil pump to fit my 03 -88motor. Ta Charlie
  • BACAMICK
    BACAMICK
    dont they change the sping in the tc88 to a Latus or Baisley spring to up the presure , cheap aswell
  • andij
    andij
    goodonya scotty you are still our tech guru .spot on .
