Online: John.R
Sporty leaking oil at 5,000 km....
  • kingchops
    kingchops
    Enforcer,
    The trans oil drain plug is at the bottom right of the primary cover (right next to where I can see the rego label, it has a rubber seal on it, I'd start by checking that.
  • MJ
    MJ
    it's ok it is not a leak it is just marking it's territory :D
  • BACAMICK
    BACAMICK
    FINALY a real HD that leaks oil , ur lucky mate
    should be a oring on the end of that cable going into ur primery , try give it a real same nip up , not to much but as them suckers can snap real easy, or the cable could  have a fine crack in it
    BUCKET is correct there , your wasting ur time checking the eng oil
  • BACAMICK
    BACAMICK
    the more i look at ur pics the more it looks like a fine crack in the cable housing
  • LOFTYBOB
    LOFTYBOB
    Julies brand new 883C leaked oil from the crank position sensor at the front of the cases. This caused oil to leak along the bottom of the motor when ridden and we thought there was a oil leak at the back of the motor. Took it back to the stealers and the said the crank position sensor oil leak is a fairly common problem You would of thought they could of had that sorted by now/
    Hope your problems are fixed soon.
