Online: John.R, evo94
NEED BRAKE FLUID ADVICE
  • 2005 FLSTFI
    2005 FLSTFI
    JUST PUT PM CALIPERS & BRAIDED LINES ON THE 05 FATTY & NOT SURE WHETHER THE DOT 5 BRAKE FLUID (SAYS TO USE ON RESERVOIR CAP) IS COMPATIBLE WITH THESE COMPONENTS.
    AND WHAT WOULD BE A GOOD RECOMMENDED BRAND FLUID TO PUT IN.
    CHEERS IN ADVANCE FOR ANY FEEDBACK
  • 2005 FLSTFI
    2005 FLSTFI
    THANKS FOR THE RESPONSES GUYS.
    PM BRAKES WEBSITE SAYS THAT THEIR CALIPERS ARE COMPATIBLE WITH BOTH DOT 4 & 5. (AS ROADTRAINS EXPERIENCE SUGGESTS)
    HOW COMPARIBLE IS THE DOT 5 BEL-RAY BRAKE FLUID COMPARED TO SAY THE H-D DOT 5 FLUID OR ARE THEY MUCH OF A MUCHNESS.
  • BAKES
    BAKES
    If you have already had a different type of brake fluid (Dot rating) it pays to flush the system with metho first
