Online: beaglebasher
2006 streetbob front brake line (swap)
  • kickinon
    kickinon
    Swapped over my standard bars for a set of fat pull backs, but the brake line is to long ,
    so lm wondering whats out there? & who has it?
    l see braided lines for sale on the net ,  they have been made up with the correct fittings
    but still not the  lenth l need, l figured ,,(45") ..(1130mm) tip to tip...
    thats about 100mm shorter than std,
    l dont mind the H.D. set up in black either,
    What have  others done  when it comes to this swap over??
    oh, throttle cables are a bit to long as well, but they work & dont look as out of place as the brke line does,,
    im going to ring a dealer when ive finished here, see what they say,
    but ive found in the past HD forum members always have  good answers on bike mods. & where to get it!!!!
  • kickinon
    kickinon
    good stuff!! thanks AKA....
  • billie
    billie
    kickinon
    Might be able to help will measure original I took off my night train
    I live in st albans so not to far away It's original harly
  • kickinon
    kickinon
    billie, sounds good, l havnt got one yet,
  • billie
    billie
    kikinon
    Have measured the hose 42inch. if you want to swap over I will be home next week end it's fine if you want to fit it to make sure it fits and I can give you a hand to bleed front brakes
    0409948198
  • kickinon
    kickinon
    hey billie !! just measured up using a piece of 3/16"coax. 42 inch will fit fine,,
    ive got your mobile # ill give you a call about 8.00 tonight(Tuesday) ill ask you then how much you want for the brake line?
    ,thanks,
