Online: B0nes, Hilly
Screaming Eagle Slip On's ?
  • Surly
    Surly
    The baffles are easily removed and the holes can be opened up or added to or the crushed end opened up to allow a little more sound out while maintianing back pressure. However, it is far easier to make them noiser than quiet again
    Surly
  • DynaRider
    DynaRider
    if you mean scr eagle 3 slash cut, then the 2 screws (tamper proof torx) near the end do retain the baffle
    I would not describe the removal process as "easy" but certainly possible (fair amount of banging required with a decent drift)
    the baffles are fibreglass lagged
    removing that packing gives much better flow and a slightly stronger exhaust note
    this process is, of course, totally reversible
  • Peter
    Peter
    Dunno what the dealer did to the SE muffs (i asked them to make em louder) when i bought my 09 softy but they are certainly louder and sound better than the old SE's on my last bike.
  • sime69
    sime69
    Mate, I've just removed the fibreglass padding from my SE's (06 Superglide). There's a shitload of it wrapped around the baffle in each one, the way the gas is routed through all that crap its a wonder the friggin exhaust worked at all....anyway they are definitely a bit louder now, but not over the top.
