Online: beaglebasher
Ultra CB Radios
  • pdr
    pdr
    Does anybody know if you can get the CB radio to work in oz?and how?
  • biff61
    biff61
    I've turned it on and got nadda, doesn't worry me though, rather hear the noise from out the back anyway.
  • grahamjb
    grahamjb
    Harley CB radios are 27Mhz which is not really used any more. 27 meg CB is HF and relies on upper atmosphere propogation (skip) to operate over any distance but the reality is that 27 meg is crap and that is why it is not commonly used.
  • PKSHED
    PKSHED
    Might as well take the right arial off then. ( I think the right side is the CB)
  • CHARLIE
    CHARLIE
    PK you are correct the right side is CB  double coil aerial on the right how many times do you see it on the left even when new i changed mine to the 09 stubbies a lot smaller and work well.It's a bit sad when you have to tell the dealer they are fitted wrong makes you wonder.Bring on UHF.Mine works fine but the wind noise drives you crazy.
  • CHARLIE
    CHARLIE
    Hoddy run UHF on the Ultra and Kenwood TS50 HF works well.VK8.
  • pdr
    pdr
    It seems Dale McLean Motorcycle Electronics in Swansea NSW has the answer with a lead that allows you to hook up a GME UHF to the Harley Radio so it works with the headset etc PH 0249715239 0410461250 dmme@optusnet.com.au Thanks to all that replied.
  • CHARLIE
    CHARLIE
    He is the one to ring it works well but seal it from water.
