Online: B0nes, Hilly
Primary noise 03 Ultra
  • CHARLIE
    CHARLIE
    Scotty if you read this am told i need to fit a 60% thrust washer to the comp nut to stop the end play float and get rid of the noise but the washer is hard to buy local stealer said no longer made?, but you can lathe down the back of the nut?.Also can you tell me how this Pm works to contact members tks.I also have a new set of 203s to fit to the Ultra as we travel 2 up, or look at the 204 as i need that little bit more to pass rest is stock for slip on's and K&N filter.  tksCharlie.Darwin.
  • CHARLIE
    CHARLIE
    Found the 060 spacer in my bag of tricks and fitted it noise has now gone and bike does not vibrate anymore steady as a rock,my question is how do you know if the 060 spacer is the right one to fit will it do any damage if it is to thick or just leave as it is and ride it.
  • CHARLIE
    CHARLIE
    Tks boys will keep it in mind hope there is not a next time but if there is.
