Online: GGUser744
JUST FITTED NEXT FXD RISERS
  •  GLEN
    GLEN
    Just fitted new Pull Back Risers made for the fat bob
     they bring the bars up about an inch and back towards you about 2 inches
    took it for a blast around the beaches of Bundi today - it was just what I needed to take the kink out of my back
    I am about 6ft'1 and I seem to lean over just that little bit on the standard ones
    I put some pictures up for you to get a look at how they sit
    if your lookin for something like this
    They are worth about $290
  • FTBOB
    FTBOB
    Mate, just what I'm looking for, are they genuine HD? Part number? or where did you get them. do they come in black? Also noted the AVON on the front, how does it compare and have you replaced the rear?
    Were the stock cables long enough?
  •  GLEN
    GLEN
    The kit is 6' PULLBACK RISER KIT - 1.25"H
    P/N HA56267-09
    under the bar code is the number 56267-09
    Yes they are genuine HD - I got them through Bundaberg HD Dealer
    only took 2dys to come up from Melbourne - I think they only come in crome
    the photos actually dont do them justice they are a very chunky and are more of a square shape
    actually the dealer didnt know they existed I searched on american sites and found them and told the dealer what the number was
    make sure if you get them that the rises come complete with 'caps' - some don't .......
    the Avon I find alot smoother and better handling than the originals - I have the cobra on the back and the venon on the front because when I bought them a few months back they didnt make the 130 in the cobra yet
    I just did a 1000km ride Townsville to Bundi and had a bit of a play on the way down and they performed very well and never let me down - but I havent tested in the wet
    ps the stock cables fit no problems at all
