Online: GGUser744
Shift light for FXDF
  • Rowdy
    Rowdy
    I own a 09 fatbob and want to fit a shit light , was woundering if anybody has fitted one to a injected moter as they run a serial data wire instead a tacho wire . Have looked at a couple of different  lights MSD digital and Pingle shift minder system ,if anybody has hooked up a shift light what type did you use and how did it wire in .Any  information would be welcome.
  • Rowdy
    Rowdy
    What pin from the ECM did you have to run the wire from and where did you purchase the Dynatek shift minder from .
  • Rowdy
    Rowdy
  • Rowdy
    Rowdy
    Have already got a speedo with a combined tacho, wiring upto speedo is a serial data line ,one wire sends signals to both speedo and tacho then internally they convert signals into a readings, still getting use to forum stuffed up double post,will have to do some more research before buying shift light ,Pingle shift minder looks the same as Dynatek ,they also have a clutchless shfting system that I am looking at  on there websight.
  • Rowdy
    Rowdy
    Thanks for the info AKA bikes in pieces at the moment getting painting and airbrushing done will post some pics when I get it back together .
  • Rowdy
    Rowdy
    Seen pics of your bike good looking Dyna
