Air Filter Swap
  • Peter
    Peter
    I am going to remove the stock air cleaner from my 09 softy and put the K&N from my 06model on and I am wondering if there is anything I should know before I try and fit it ?? From memory, the shop originally fitted an SE backing plate with the K&N filter to the 06 model so that is what I will be fitting to the 09. I assume I should buy a new gasket and o-rings but should I be using locktite on the bolts and is there anything else I need to know ?? Thanks for any replys.
  • hattown.nt
    hattown.nt
    Make sure the tab that is in the way (if the S/E back pate has it) gets filed down took me about 3 minutes with a rough file. I don't use loctite on air filter cover, have had 1 bolt come loose only once. Make sure you use grease on both sides of filter so it seals properly....
  • angry
    angry
    you will probly need to remap or rejet to get any performance benifit from it. bike will run a lot leaner with free flowing aircleaner.
  • Peter
    Peter
    Job done TMAX installed as well, running sweet.
