Online: baldy1450
Right indicator not working. Do we have fuses?
  • wazza-in-oz
    wazza-in-oz
    Guys need some help.  Have a 95 Heritage and right indicator has suddenly stopped working, both front and rear one.  Have I blown a fuse?  Do harley's have fuses?  Please help.  Thanks.
  • wazza-in-oz
    wazza-in-oz
    Thanks Ray.  Globes are fine.  I checked my service book but it doesn't say anything about having fuses?  I thought it must be the switch as well.  I will check it and get back to you.
  • Peter
    Peter
    Do a diagnostic check and see what error code is showing up. Whoops sorry Wazza, i just re-read your post and realized you have a 95 model.
  • wazza-in-oz
    wazza-in-oz
    Yeah no computer unfortunately. Does my bike have a fuse for the indicators? If it does where are they?
  • Fat-Boy
    Fat-Boy
    I'm no tech head but check under your seat??? I got a whole box of fuses under mine...
  • twincam88b
    twincam88b
    I had the same problem with my 03 Softail........the problem for me was the connectors behind the rear tailight. There is a heap of small pin connectors (for tail light and indicators ) and the moisture had rusted one of the pins. Bad design really. Rain water from your wheel can enter through the hole the wire passes and gets in the connectors. Your light is a bit different, because of the 2 mudguard styles, but worth a check. Remove the 2 screws to remove the lense and look behind the backing plate. The dealer fixed the problem even though it was out of warranty. I did seal off the holes better once I got home. I rekon my current bike 08 has more grease plastered over the connectors. I did some searching before and I came accross a product called Permatex Spark Plug Boot and Electrical Connector Dielectic Grease. Haven't bought any yet, but that reminds me I had better get some as this postit slip, with the above details, has been on the fridge door for a couple of years now. Hope that helps Wazza.
  • wazza-in-oz
    wazza-in-oz
    Thanks. The problem now goes deaper. Check out my new thread - Electrical problem please help before I throw a match at my bike!!!!
