Online: beaglebasher
TMAX INSTALL
  • Peter
    Peter
    Ok, I am just about to put the Tmax in the 09 softy and I have contacted Zippers and they say to use Map401 for my bike with SE muffs and K&N filter. My question is can I adjust the warm engine idle speed down to the 970rpm I set on the 06 model ?  Any other info would be appreciated.
  • Peter
    Peter
    Thanks HogBag, I think I asked a lot of the page 10 questions.
  • Peter
    Peter
    Just for future forum reference, I put the open loop TMAX in and loaded map 401 and the thing is purring like a kitten. No popping or backfiring, just runs sweet.
  • BACAMICK
    BACAMICK
    be aware they recon under 1000rpm ya loss oil presure on these new suckers
  • Peter
    Peter
    The map has put hot idle at 944rpm so I hope that will be ok, according to Scotty it was anyway ? The only other issue I have is that I have lost the "km's to go" function on the dash but a later update when Zippers sort it out will hopefully fix that. I think I can get by without it though,LOL.
  • aussiesport
    aussiesport
    ditto on that scotty am waiting for the tbw 09 model to come out ! will be a few months still yet
