Online: B0nes, BoltLeftover
New starter map TTS
  • Fr3d
    Fr3d
    Hi Scotty, my 103 08RKC with TDuals, SE mufflers and 211's has been running well on the current TTS tune that was based on the TQ205 map.  Due to my overall disappoint ment with the HD 103 build I changed the slip on's to V&H Basic slipons and it did not run very well on the final map that was developed for the SE mufflers.  I thought it would be ok since it was only the mufflers that were changed.  I then went back to the TQ205 base map but still have trouble getting the bike to run smooth enough to feel its the right starter map.  The bike has been popping, spluttering and presenting with some bad dead spots down low in particular with these maps.  Put the SE's back on and no problem.  Its seems I just have to get the right starter map.
    Would I be better off going to the YB205 since its got TDuals, cams etc but since its 110 just changing down to 103 in my constants?  Any other ideas would be appreaciated.  Thanks Fred
  • Fr3d
    Fr3d
    Thanks, will go with that
