front fender riverts
  • seaeagle
    seaeagle
    has any one removed and replaced these riverts?
    any reason it cant be done with some kind off nnut and bolt?
  • The Don
    The Don
    Hi Chris,
    When I had my 81 FXEF I decided to change over to a Wide Glide front end.
    I did however, keep the 19 inch front wheel. This caused a small problem in the looks dept,
    the fender was up too high and it looked like a trail bike.
    Modified the original fender, made some s/steel sides and replaced the rivets with s/s dome
    bolts with locknuts on the inside. Just check for clearance with the tyre and they should do the trick.
    regards,
    Cris
  • seaeagle
    seaeagle
    thanks cris, ive got a 21" not changing anything, just painting it, with the rivits there they make it look cheep...
  • Shoveltrouble
    Shoveltrouble
    I done the nut and bolt thing a while ago, no issues at all.
  • seaeagle
    seaeagle
    thats settled then.... and ground off....lol, mabee should of found the bolts first..lol
