Online: B0nes, BoltLeftover
rekluse clutches
  • Gang 20
    Gang 20
    any one know of a product similar to the rekluse, they only make them for 1990 onwards bikes, mine is 1986. also does anyone know if they are any good, my bike has a bit more horses than a stocker and how do they handle the bigger horses
  • Lastrain
    Lastrain
    Hi there Gang 20,
    I have had abit of a look at these and wondered if they are any good, never actually seen one in use, try you tube or google there are a few vid of them posted about. There is another on the market made by RevLoc, works the same as the Rekluse Pro Start, not sure if they are available for your 86 but they are available for Evo's though I am not sure if there are differences between 86 - 90, they do make a high preformance unit for drag and pro street use which can take well over 100+ hp
    Check out their website www.revloc.com you could try e-mailing them to find out if you can get one to suit your bike.
    would like to hear from anyone who has one or tried one
  • hattown.nt
    hattown.nt
    Why would you want one on a harley???
    Some blokes use them on dirt bikes, all they do is stop engine breaking....
