Online: beaglebasher
Samson Ground Pounders/Street Sweepers
  • AJ56
    AJ56
    Looking at the above pipes for my 07 heritage.  I have read a couple of places that they had issues with Chrome Work on the pipes in years gone by.  has anyone had any issues with them.  I like the design of the pipes but would appreciate some pro's and con's if there are any.  Also anyone advise on place to purchase them in AU.  I know what the price is in US dollars but they don't ship to Aust.
    Any advice appreciated or are there better pipes out there with the same look.
    regards
    AJ
  • hattown.nt
    hattown.nt
    I've got them on mine,gone blue real bad although not sure of the manufacturer. If your bike is low then don't get them as they will scrape.
  • mickrod
    mickrod
    i have ground pounders on my vrod, got mine from mcas, they have a website you can order them from, mine only went blue on one pipe from a baffle that was to restricting, the other one fell out, polished out though, hasnt come back since i fitted decent baffles, they are 16000 kms old now
    I sell Ground Pounders , They are only Chrome Plated Finish and that is why they go Blue They also dont have a Baffle thats why they are loud and you will most likely have a Back Pressure problem with them because of not having Baffles.
    Bassani Make a Ceramic Coated version with Baffles, They dont go Blue, have a great sound
  • AJ56
    AJ56
    Walka can you let me know what sort of price am I looking at,   Regarding the back pressure do the power cones solve that problem?  And can a set of baffles be fitted to them ?.  At this stage I wont probably get them till the new year.
    AJ
  • AJ56
    AJ56
    You blokes have put me off these now. I will have to think about alternatives. The reason I was looking at those is that I have put on a set of swing arm covers and can't see the right hand side due to the S&S slip ons. The GP's and SW's don't come so far back along the lines of the bike. Back to the drawing board.
  • hattown.nt
    hattown.nt
    V&H's or simular short shots???
