Online: Neale
Stoplight
  • Peter
    Peter
    I was told that you can now buy a smoked tailight / stoplight for a softail that fills the entire space between the rear fender on E-Bay for about $80, it apparently screws straight into the original holes. But I can't find it, has anyone else seen it for sale ????
  • TNT
    TNT
    No but will keep an eye out Pete sounds better than $410 for the LED Trilight at the dealers, but they do look shit hot hey
  • Peter
    Peter
    From the information I got the $80 light fills the fender the same as the stealers does but is not an LED light, it is tunneled somehow so it just screws into the original 2 screw holes.
