Online: beaglebasher, FatMat
wet sump 85evo
  • Gang 20
    Gang 20
    always had a problem with it wet sumping and oil out the breather after it has sat for a while, the ball bearing and spring in the ol pump are causing the problem i think. can they be changed out on the bike or does the oil pump need to come off and the seat for the bearing need seating or emery
  • Gang 20
    Gang 20
    thanks 4 that Scotty, thought so but good to have it confirmed. should i replace the oil pump with something new that does not have that wet sump problem or do they all do it regardless of make
  • Gang 20
    Gang 20
    Thanks again scotty, well just savedme the money on a new pump, good idea about the evo pushrod tho was wondering how i was going to do that little job
