tts question for 06 nightrain
  • v63800
    v63800
    Anyone know if a 06 nightrain ecm has wiring connectors for o2 sensors.Looking to buy a tts but not sure i can use all its features.
    Thanks Phil
  • v63800
    v63800
    Scotty thanks for the reply.
    I'd be keen to have a look at the wiring diagram and part nos.
  • v63800
    v63800
    Scott,
    thanks for the wiring diagram and part no.s.
    just had a quick look at the tts tuning guide.
    it mentions that the ecm needs the correct ecm firmware on page 5 to support the o2 sensors.
    will the tts unit update the firmware if required.
  • v63800
    v63800
    scotty
    can i add the tts first and run an mt6 file and add the o2 sensors at a later date
  • v63800
    v63800
    scotty,
    thanks again for your responses to my questions.whats the availibilty of these units as i'm looking to purchase one in 2 weeks
  • v63800
    v63800
    scotty,
    would this be a good base map to start with.
    np141-025
    stock 1450 nightrain with v+h sideshots
    thanks phil
  • v63800
    v63800
    scotty,
    thanks for supplying the tts.installed the map you recommended to suit and found the bike does't lug around as much as it use to.seems to have  cleaned up any throttle issues and pinging and pulls clean through all the gears.
    the 02 sensors and  connectors finally turned up today so hoping to install them this weekend if time permits,afl grand final and all.
    what sort of wire should i use to get the sensors hooked up.probably got a choice of repco,supercheap and a few local auto elecs.
    thanks phil
  • v63800
    v63800
    scotty,
    could you make that 176 map as i'm ready hook into the ecm.
    88" 8 degree injectors with correct timing.
    thanks phil
  • 2005 FLSTFI
    2005 FLSTFI
    Sorry to hijack this thread, but I too have just installed o2 sensors, would that mean that I need to install the 25° injectors as well. Havn't put the TTS on as yet as I plan to do it at christmas time with a 176 map.
  • v63800
    v63800
    scotty,
    still trying to get my head around this as the tts map np141-008 for open loop that i'm currently running lists the injector at 3.91 also,shouldnt that map be 4.35 for 8 degree injectors.
