Online: B0nes, BoltLeftover
kill switch
  • wally
    wally
    I thought the idea for a kill switch was to short out the coil , i did this by shorting out the main
    power feed to the coil, all this did was smoke up the switch wiring and i think knackered the
    switch .I am now thinking the right proceedure is to short the two terminals on the coil that feed
    the front and rear pots (single fire ignition ). can some one confirm that this would be correct
    before i burn my shed down .
    wally.
  • blueystar
    blueystar
    hows it going wally sort the mufflers out
  • wally
    wally
    G'day Bluey , yes the mufflers are on but certainly are very restrictive , so much so
    the motor seemed to be flooding , 80 k's top speed ! I put a crowbar through to
    make about 1/2 " hole in each which helped , when i get passed the sound test with the engineer
    I'll stick the crowbar right through . The cv carb jets have most likley been messed with
    in a previous life , i just want to get the thing engineered and on the road .
    Hows your new unit going then .
    wally
  • wally
    wally
    Thanks Ray , i have trouble getting how a coil actually works , like theres
    threes wires coming from the ignition modual to the coil ,power , front ,back cylinder
    thought if i short the power one would kill the lot.
    wally
  • blueystar
    blueystar
    WALLY I HAVE REPLACED MY CARBY SO IF YOU LIKE YOU CAN HAVE MY OLD CV CARBY THAT WAS WORKING FINE
  • wally
    wally
    Bluey ,
    thanks for the offer of your old cv but i'm sure this one is ok , it just
    needs some attention that i havent given it , its been sitting for some
    time and i expect it to work correctly first time,thanks very muchjust the same .
    Scotty ,
    please accept my apology , this is a flogger that i am scratching together , it is an 1993
    evo motor with a crane HI 4 ignition with a single fire coil, making my own wiring harness
    and having difficulty in working out how to incorperate the kill switch . My clymer wiring diagrams
    all have dual fire coils so i can't follow them as my coil has a terminal for each cylinder .If i only
    earthed 1 pot through the kill switch would this be sufficient to kill the motor or would she still run
    on one ?
  • aussiesport
    aussiesport
    dont quote me but we used to run the kill switch on the positive wire to the coil so the switch effectivly cuts flow to the coil so it cant fire or buildup to fire ,not actualy shorting anything out at all?! just a thort ..
  • wally
    wally
    Scotty ,
    its a little modual in the nose cone
    Aussie,
    i was thinkingto send the cuurent to earth would stop the coil from working
  • wally
    wally
    Scotty ,
    thanks v. much for your time and thoughts and imputs ,because the red ignition wire
    and power feed from the key are both joined on that centre post i think i'll just melt
    the wires again .
    my plan now is to run the power wire from the ignition switch through a normally closed relay
    and run kill switch on the other side of the relay so when the kill switch is pressed the circuit
    completes therefore cutting the power to the coil . But i'm going to try your way first because i
    can't find a normally closed relay, if there is such a thing.
    thanks everyone for your help .wally
