speedo/tacho combo
  • cattleprod
    cattleprod
    Just got a HD speedo/tacho combo to replace the original speedo off my FXDC
    Just wondering if the HD gurus here, know of any install issues, tips and hints.
  • cattleprod
    cattleprod
    Dazza, thats what i came up with when i got home from work.
    1/2 hour all up, switched on all perfik. Have Tacho...
  • shfunky
    shfunky
    do you have pictures?  how much was it if you dont mind me asking?
  • kensim
    kensim
    yea they put one on the dyna they did up in heavy duty mag,they look cool man. ilike having a tacko too.
  • cattleprod
    cattleprod
    No pickies as yet.
    Can't remember exactly what i paid, around $400 landed.
  • pva68
    pva68
    Well don't keep us in suspense. Take a piccy and post it for us....
    Was it worth the $400 odd bucks you paid to have the tacho on the dash?
  • ==ShaDoW==
    ==ShaDoW==
    got mine on the way as well, cant wait to have a tacho on the bike.
  • pva68
    pva68
    have ordered one of these.  If my wife is good will have it this weekend (fathers day).
  • pva68
    pva68
    Got my new speedo.  Love it.  Easy to intall.  All data straight onto it from ECU.  Could not be happier.
  • FXDF12
    FXDF12
    Looks good!
    Dealer told me they had to install it or it would not work something about transferring milage etc. but if it is a home install job will have to grab one.
  • pva68
    pva68
    It was an easy home install. Only thing is if your bike does NOT have ABS the dealer needs to update the ECM so the ABS warning lights don't stay on all the time.
    All mileage info is held in the ECM and was updated instantly on the speedo when it was first turned on.  EASY.
  • The Phat
    The Phat
    I love this combo. Bling with functionality. This plus flush mount tanks will change things up nicely.
