Online: GGUser744, Hilly
Head stem bearings
  • Wingy
    Wingy
    Will the dearler really ......ADJUST/LUBRICATE  head stem bearings on a normal service ,as per 15% off
    pamplet I just recieved in the mail....big job on a Superglide with no grease nipple....................
  • twincam88b
    twincam88b
    On my Road King it came with a grease nipple the same as RT shows. Couldn't access it properly (maybe this is why the dealers don't bother greasing them) so I bought a right angle grease nipple. Works a treat. I have checked after a service and I don't think they have touched it, well not sure anyway. So do it myself. Give it a few pumps when I think about it. The grease does work it's way out the bottom in the summer time. Just drops on the bottom T and I wipe the excess off with a rag. Doesn't fall on the front guard. At least I know it's getting plenty of grease.
  • Wingy
    Wingy
    Roadtrain........when you did yours did you pull everything apart or use alot
    of grease on the drills and taps?????????????? If my HD is anything like all
    my Jap bikes that I have done head stem bearings on they all had fuck all
    grease on them from new........................... XR 350..  TT600...XR 600.......
    GS 850........XR 650............................
  • hattown.nt
    hattown.nt
    1 grease nipple in the middle of the stem, does that lube both bearing's properly??? That's something I'll look into doing....
  • Wingy
    Wingy
    Sounds like a fair bit of work and a bitch of a job ....I think I will get the dearler to do it...
    get a service ,all 3 holes + oil filter ,new spark plugs,  check over  , head stem adjust/lubricate and
    a wash for $320.45 sound like a bargain....I can sit in the pub and ride a clean bike home...
