Online: Retroman
changing grips on FatBob
  • rockyrob
    rockyrob
    HI guys my first question to the forum , and yep its  probably a dumb one  but no matter,  i am changing the stock grips on my 09 FatBob to HD chrome and Rubber and was just wondering if theres anything tricky to worry about with the RH throttle assembly when i do it,  Have rebuilt my old Norton from ground up changed cables , and god knows what i havent tampered with. .  I dont have a problem pulling it apart and stuffing around until i get it right,  but  a shiny new Harley ? I figure LHS  just loosen the assembly and postion the grip correctly so it locks in , but i am just a bit concerend abouth the twin cables as its something i have not seen before. Any prior advice getting the dealeris not my ideal preference.
    Rob
  • PigironBob
    PigironBob
    Yeah, be carefull not loose the little brass thingy that goes onto the end of the cable, unlike a lot of cables these days the Harley end is not pressed on.
  • FXD09
    FXD09
    15 Jun 2009 11:20 PM Quote Reply Alert
    2009 FLHT Electra Glide Standard Denim Black
    'Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out,
    shouting 'Holy shit...what a ride!'
    They are a bitch
  • rockyrob
    rockyrob
    OK  I ,ll bite  whats a T25 and T 27, and  are Harleys imperial or metric . If i ever get out of the office and into the garage  i can  find out  but the T25  got me curious
  • PKSHED
    PKSHED
    Get a good set of Torx  sockets from Snap on, if your gonna service and work on ya bike, you'll need em.
  • rockyrob
    rockyrob
    Thanks for the advice guys especially the heads up about the brass end bits, one of the little suckers shot str8 into the air ,lucky i was told as my eyes and ears went str8 into looking for it to land,  found it no probs,  The LH grip was actually alot harder than the right to fit  for some reason,, but all done looks good pics to follow
