Online: B0nes
  • Peter
    Peter
    Will a TMAX (non auto tune) that is now on a 2006 twin cam be ok to use on a 2009 Twin cam ??
  • Peter
    Peter
    Thanks Scotty, I can live with that as long as there are no lights staying on or bells ringing. LOL. I forgot to ask if the K&N filter will be ok as well ?? Thanks again for all your patience, as you have probably read I am now trying to decide if I should go with the tensioners and cams for my bike or buy the 09 model at what seems like a pretty good price. Anyway, Thanks again.
  • Peter
    Peter
    Whats the story with the sensors that are on the standard 09 pipes Scotty, do you have to disconnect anything when you load the Tmax map into it ??.  The guy at the shop said it's not neccessary anymore and added that you used to have to jam something open on the 07's but not on the 09's ?? It looks like I will only be adding SE mufflers so what problems will I have if any and how do you think the thing will run with the standard ECU until I get around to putting the TMAX and K&N filter in ??
  • Peter
    Peter
    So should I start with the original map and work from there with your help ? LOL.
