Online: GGUser744, Hilly
Dyna queries.
  • Victa
    Victa
    Gday,
    I've just bought a new 09 dyna superglide and am looking to trick it up a bit and was hoping for a bit of help or advice.
    Firstly, Does anyone know a reasonably priced store in the U.S. to buy a set of Vance&Hines Big Radius 2 into2 pipes and should I run the engine in before I fit them. They are $1200 in Aus.
    Secondly,Same again but for seats. I'm looking at fitting a Lepera Daytona Sport Regal Plush seat . Hopefully should like good and feel comfortable.
    Being a shortass I need to lower it so I've bought a 1 inch lowering kit and with a low profile seat I should be right. Has anyone used these lowering kits.
    Any help or advice would be greatly appreciated.
  • hattown.nt
    hattown.nt
    Hi,
    As Retsurht said you'll need to do tuner and air filter, but you can get Hooker troublemaker pipes look very similar to the V&H
    You can get them from www.hdbitz.com.au
    for around $600 I think.
    As for the lowering kit, I'm not sure being a Dyna I thought you had to buy lower shocks, I've put 11inch lowered shocks on my wideglide, heaps lower but a lot stiffer
    and I have the badlander seat, I'm 5'5" and can now just touch flat footed.
  • sly-1
    sly-1
    vance and hines pipes will cause decreased horsepower , but if that doesnt worry you they do look good
  • Victa
    Victa
    Thanks everyone for the opinions and advice. I've bought the V&H pipes and am fitting a V&H Fuel pak tuner module.
    As for the rest of the parts I sourced them on ebay and got great value for money.
    Thanks again.
